Complete part out v6 turbo gn1 heads rockers turbo injectors DP etc
Interested in power steering set up.
I have the pump with powder coated pulley and tank, cap with metal fender bracket. 270 shipped. image.jpgimage.jpg
Parts available update as of 8-1-2015 Text me @ 786-262-six six six six for a quick response. Thanks Henri...
1- 80 lb injectors like new (800 miles) from TT $215 shipped
2- 50 lb injectors with tt alky chip $150 shipped
3- K&P oil filter filter $120 shipped
4- 3.5 Downpipe internal gate, G body parts with cat dump$240 shipping to be determined on this part
5- Duttneck intercooler and shroud $275 shipped
6- 1987 Limited grill nice $275 Shipped
7-Cam sensor and cap $165 shipped
8- engine wire harness no cuts $225 shipped
9- oil dipstick and tube $45 shipped
10- stock intake clean $175 shipped
11- poly mount drivers side $110 shipped
12- Fuel rail painted or powder coated golss black $50
13- Throttle body with IAC, TPS, very clean $160 Shipped
14- Complete power steering set up, pump, pulley, lines, tank $275 shipped
15- Frame stands L&R $55 shipped
16- Exhaust manifolds with crossover, have been welded in the past, not pretty but no leaks. $145 unsure of shipping on this
17 Doghouse excellent shape $85 shipped
18- Crank pulley powder coated (multiple pieces everything on the balancer hub) $75 shipped
19- water pump pulley powder coated $40 shipped
Interested in the K&P oil filter is it a (S18) and oil dipstick and tube, pending pictures.
Updated list as of 8-1-2015 You can text me @ 786-262-six six six 6 for a quick response Thank you all Henri...
Parting out my entire v6 turbo package going V8.
Located in Miami Fl 33162
Also have 109 block n crank not hurt $450 but will need local pick up Miami Fl 33162
Many other parts to be listed
Buick parts 4 098.JPG Buick parts 4 066.JPG Buick parts 4 069.JPG buick parts 025.JPG buick parts 051.JPG buick parts 033.JPG buick parts 054.JPG buick parts 081.JPG buick parts 055.JPG buick parts 3 010.JPG
I'll take the dipstick and tube if available
Are the AC Lines Available? Headers, the tree branch looking bracket that bolts to the alternator in the back and alternator bolt (the longer one) and the passenger side intercooler bracket? if so, How much?
Kirban AC lines like new 175 shipped (huge box to ship this), branch bracket, the tubular one not the flat $55 shipped, Headers with crossover 145 shipping to be determined, no intercooler brackets, ill give you the bolts you need if you buy the branch bracket. Thanks Henri...
The harness is out of my running car just removed a few weeks ago. The harness is perfect I only peeled back the insulation on the yellow knock sensor wire near the ecm, no cuts or splices anywhere. If you want a clean harness this is it. Thank you Henri...buick parts 044.JPG
I need the wiring harness plastic L-shaped cover bracket. Would you sell that separate from the harness?
I didn't see it but did you have or sell the brf trans
or keeping it?
Sent from my XT1254 using Tapatalk
