TR Custom Parts
Mark Hueffman - Owner
- May 25, 2001
Finally got my GN up and running and have about 10 minutes of run time on it. New TA timing chain, Champion ported heads and intake. Took the front end down to the bare frame rails, new tubular control arms and neatened up the wiring. Also stripped and painted everything except the roof and quarters with the exception of the hood and bumpers which I had done a couple years ago.
Anyway got a code 34 and have done some research on it but haven't dived into it yet with the exception of changing out the MAF which did not clear the code. Yes I reset the ecm. Z06 sensor with Translator Plus. Everything was carefully stored away while the car was down for the past 6 months. Here is my dumb question.... could an incorrectly installed cam sensor cause this code by any chance. Followed the procedures for the cam sensor by the book and everything seemed to be fine. TDC on #1 compression stroke verified by feeling compression coming out the sparkplug hole. Rotated another 1.45" past TDC to the mark I made on the balancer matched to the 0 mark on the timing tab. Also sure that timing chain/gears were installed correctly. Used Caspers tool to set the cam sensor per instructions. Car started right up but set the code in about 5 seconds. Falls on its face when I try to give it a moderate amount of gas. Got to hobble it over to get a front end alignment tomorrow a few miles from the house but sure would like to get this thing back to where it was before I took it apart!
