m3x1c0
Bad luck Buick
Im getting ready to add another accessory that will need a constant 12v supply. I refuse to run a wire to the battery because I hate the way that looks so I will look to power it somewhere off the fuse box. However, while I was quickly rooting around under there today I realized my alky power connection came off with a slight pull on the wire because the fuse block connection doesn't quite have good tension. This got me thinking about a more solid connection using some sort of terminal. Has anyone created a nice breakout terminal box for power to clean up there wiring under there? It's basically a rats nest from factory so anything I can do to make it cleaner will be wonderful. Any wiring pics would be greatly appreciated!
