Scott89TTA
- Jul 12, 2005
Trying to get some specs for the Champion P&P big valve heads for TTA not GN. How many CC's are stock TTA heads and if they are different after being worked by Champion what are the new numbers? I need to calculate compression for a possible build. I think the TTA compression is around 8.1:1 or 8.3:1...is there a particular range I want to stay in...is 8.5:1 or a little higher going to be a problem?
I Sent Champion a message and called...only got answering machine and message said the box was full so couldn't even leave a message?
Thanks,
Scott
Thanks,
Scott
