Casper's Audible Knock Detector Wiring?
~JM~
Wrinkled Member
Is a wiring T splice somewhat like shown below adequate for wiring the Yellow/Black wire?
22-18AWG-Female-T-Tap-Male-Insulated-Connector-Wire-Terminals-Quick-splice-Disconnect-Combo-Tips.jpg
Is there something better?
Trying to avoid cutting, splicing, soldering, original wiring.
Thanks.
PS. Is there a source of switched 12V nearby, or just run a wire to the fuse panel?
If it's a quality T splice it should work.
If you run it off IGN 3 for +12 it won't work when cranking and won't annoy you.
Otherwise you can use the ECM power IGN pink/blk wire on A6.
