Bunch of stuff. Step in !!
Fat Nat
Siemens low imp 83lb injectors 200
Rjc boost controller 25
Engine tie down new 25
Vdo oil/water gauges with senders 50
Intercooler fan 50
Auto meter 5” cobalt tach like new 200
145mph speedo cluster will need reducer for speedo cable 200
Power steering reservoir 95
Kirbans Gnx fender vents 30
Boost/tach modules 40each
Hurst 3 speed fwd pattern shifter w cable 150
Harmonic balancer 60
Standard press adj waste hates new 40each
Adj fuel press reg 40
Liquid fuel press gauge with fuel rail fitting 50
Will the shifter work with a TH400 with no trans brake and no RMVB? If so I’ll take it. Shipped to 39503
Yea that’s the one you need if you don’t have reverse pattern. You will need the linkage for the trans I’ll send what i have. Linkage isn’t much to buy from summit see what I have laying around the shop and I will put a weather pak plug on the button and give you the other side to wire to a line lock if you have one
PayPal is fatnat274@comcast.net add 10.00 for shipping
I’ll send payment today.
Intercooler fan 50
I will take engine tie down if still available
Intercooler fan 50
Are the boost/tach modules actually functioning correctly, or are they just cores that need to be recalibrated by Casper's?
