m233roller
Banned
- Jan 25, 2002
1- set of black MSD 8.5 plug wires that were on my engine for one summer.
These are the ones ( Shane ? on the board was making and are nice wires. I have no idea how it happened but two of them have a small split on the boot end of them ( see pics ) I really think a little super glue & they'd be fine. Cheap at $35. SOLD !!
2- A complete power antenna harness. $25
3- Complete set of gray rear seat belts that are very nice with the exception that the black has come off two of the buckles but as you can see there is an extra one with the set. $75 for the complete set. SOLD !!
4- Pair of original GM front shocks off my 37,000 mile car and are in great shape. $35 SOLD !!
5- Two almost new hood shocks. $25 for the pair.
6- Refurbished front license plate mount with the two bolts. $25
7- Pair of GN gray and t-type blue rear quarter panel inserts. $25 a set Gray ones are sold !!
8- Original GM 21 bolt timing cover in very nice shape, very minor scratching in the gear pocket but will hurt nothing. Also has the normal wear spot from the cam button. $50
9- 3 T-Type center caps that are NOT broken at all but the center emblem & cap are faded. $10 each. SOLD !!
10- Two new TTA or GNX center caps with the fire bird center's. $45 for both.
11- A complete EGR set up off my 37,000 mile GN. $75
12- Two w/s washer bottles one has a chrome cap. both in very nice shape. $25 for the one and $35 for the one with the chrome cap.
13- Brand new injection harness bought from turbo89? Paid $116 and shipping will take $75. This is a very well made harness. SOLD !!
14- An excellent right side exhaust manifold that I cleaned the welds up in the ports, sandblasted it and painted with VHT Hi- Temp black paint.
End bell is nice and round, this is about the nicest used one IV'e seen $75
15- New relay delay. $75 SOLD !!
16- Perfect rear defroster switch. $25
17 - Two nice door jam vents. $25
18- Brand new left door latch. $50
19- Nice egr covers $15 each.
20- In dash mounting piece for right side adjustable mirror. $15
21- Chrome mounting piece for drivers mirror. $15
22- Perfect stock vacuum block. $20
23- CORRECT grille springs that I refurbished. $20 a set.
24- Mounting plate that mounts powermaster to firewall. $20
25- Original Positive battery cable that's in excellent shape. $50
26- New big brass fitting that goes into front of block for oil return line. $15
26- Excellent plastic connector that goes to oil sending unit. $10
27- Two vacuum lines that go to the fpr. One is brass and one is chrome. $10 each
28- Excellent oil cooler adapter. $45
29- Good battery hold down. $20 SOLD !!
30- Timing pointer for front of timing cover. $10 SOLD !!
31- Nice engine lift hook. $15
32- Bracket that holds upper radiator hose. $20
33- Bracket that bolts to tranny pan for shift cable. $25
PLEASE NOTE ALL PARTS ARE PLUS ACTUAL SHIPPING COST.
IF PAYPALING PLEASE AD THE 3% FEES OR SEND AS FF.
Thanks Mike
Thanks Mike
