hey all,
trans is the original core from our 1985 monte ss which we bought new, so its a one owner. the current buildup was done in year 2000 by jimmy's trans
in mundulein,illinois. it has right at 10,000 street miles and no more than 100
strip runs. first 9000 miles and 90 strip runs it was behind a 350c.i.d./330h.p. gm crate motor. the rest of the time it was behind a 630 h.p./413c.i.d. both carbed and no nitrous ever and no transbreak. last fall/winter we built a 787 h.p. small block, and chose to put a turbo 400 behind it. so out came the 2004-r and current converter.
the build includes a PTS EXTREME billet input shaft and a PTS EXTREME billet shafted forward drum. billet servo, level 10 shift kit,manual/automatic valve body setup, bottom feed filter with pan spacer, the usual boost valve mods,seal retainer, extra clutch plates,h.d band,etc. .....i can forward to you the details that are included in jimmy's build.
we have had two different vigilantes used with the trans. the first one was a vigilante 9 1/2 3400 stall (just sold it). the latest converter is a vigilante 9 1/2 single disc lockup and was new in 2007.
when purchased new it was stalled at 4500rpm. it has 1000 street miles and 10 strip runs. we had it restalled to 5800rpm over the winter thinking it would matchup better with the 787 h.p. motor. in this 5800 config.
it has seen a half hour on the street this spring FOR CARB TWEAKING and thats it. we then went to the turbo 400. it is now out of the free restall adjustment period, but precision said that they would do a free restall on it to whoever bought it.
i will pay shipping to precision for the restall and they will forward to you.
the trans is solid and still works well, and the converter is practically new and was inspected last fall during the restall. fluid/filter changed three times since the buildup. last time was this winter...... fluid came out clean and red.
can forward pics if needed.
$1800 trans and converter...... plus shipping
$1500 trans only..... plus shipping
$450 converter only..... shipped
call 309-853-9671
or 309-853-7035
thx jeremy and jerome baker
jbaker@kresscarrier.com
call 309-853-9671
or 309-853-7035
