Built 109 and 200-4R
Trader history for gibbstroy (0)
gibbstroy
Im going Stage II, so Im offering up my engine-transmission, from the throttle body to the oil pan, headers-turbo-and down pipe, Extreme Automatics built 200-4r with 9.5" PTC nlu 3400 stall converter and trans brake.
Basically a complete setup in a box. Just drop it between the fenders , add your engine management, and go get some 9 second time slips.
Its a forged and girdled 109 running on e85, 8.7cr, 216/219 roller cam, cnc series GN1 iron head, 6466BB precision turbo, Injector Dynamics 1300x injectors, TR6 ignition with 2step. Built by Induction research in Mn. in 2013. I have most receipts from the build to go with it.
I pulled the heads and refreshed when I bought it, just to be safe. The machinist didnt have to do any real work to them, just polished the valves, added brass guides and put them back together.
I do know of a rear main seal leak, which is common, and now is a good time to replace it. The header crossover pipe previously cracked and has since been welded. I dont know of any other issues to note.
It makes an awesome street strip combo. Its around 750-800hp at 35psi. Best 1/8 was 6.18 at 3660 pounds. Ill be looking for $15k total obo. You can see it run and do a compression test before it gets pulled. Ill even take you for a rip in it with cash in hand. Local pickup preferred. Freight extra.
Theres probably 4-5k miles on the build, its rarely driven on the street, only because theres no A/C. When I do drive it, it never gets over 175 degrees. Previous owner ran it a few time just to say he went 10.0. I bought it three years ago and did some minor upgrades. Ive run in the TMCCC racing club (10 scheduled 1/8 mile races) for the 2018-2019 season but only made half the races. 2020 was cancelled and Ive run half the season this year so far. So somewhere in the dozen or so passes. I ran a dozen or so passes before then to tune and get used to the car. It keeps getting faster.
gibbstroy
Photos
gibbstroy
It would be much easier for me to sell it all as a package, but I might be interested in an offer. What do you have in mind?
gibbstroy
Only bad thing about piecing out is dealing with dickbeaters. ;) AND it does take a while to sell off everything. Good Luck
So true. I realize that this is a pretty specialized thing to try and sell, with only a small number of interested people. But Ive actually been asked for just the short block... Crazy. When I was looking for an engine, it would be sold as soon as I found it. lol
crazyturbo
Sent you a pm couple days ago. If you do decide to part it let me know what you would be asking for the short block.
gibbstroy
Im sorry I missed you two. Im located in North Dallas. But I currently have a sale pending for the whole package. I will reply back here if anything changes.
longbedGTs
high on gas fumes
I bought this setup from Troy. Awesome deal from start to finish...thanks a TON! Replying here because this is far more serious than I've ever been with these motors and want to make sure I'm doing this right. Going to start a thread later to get some insight and to get the parts list started. Thanks.
