Had the car dialed in... finally. Set at 22pis and ran amazing. Alky installed, all the sensors were set etc etc..
Drove it today and it was driving amazing. Stopped at a car show of all places and on the drive home I noticed a weird hickup in 6th gear, would be chugging along fine at 2000 ish rpm then bog and return.. thought it might be my tranny setup since Ive been tuning it. But it got worse and worse and worse until it started stumbling in all gears, worst off idle. It even does it when in neutral.
Fuel pressure is right, all the readings on the scanmaster are correct, o2's are good, seems like the maf is good (85mm z06 with translator). No hoses I can see disconnected under the hood, no check engine light or mal codes on the scan master.
Any ideas? I'd guess fuel pump or something but the fuel pressure wasn't moving even when it stumbled
