The brake light in the dash isn't connected to the ECM in any way is it?? I just installed the SSBC big front disk kit and rear conversion kit. I got every thing installed and gravity bled the system. I forgot to do the rear e-brake adjustment before testing the brakes. I figured I'd need to pump the brakes a time or two to get the pistons against the pads. I pumped the brakes a few times and the light comes on in the dash. I remembered the e-brake procedure and you adjust the piston out by setting and releasing the e-brake. I did that a few times and soon the e-brake tightened up. The pedal firmed up nicely, but the brake light doesn't ever shut off. I put in a center console e-brake a while back and thought maybe my handle wasn't releasing all the way so I unhooked the wire in the drivers kick for the e-brake, but that doesn't shut it off either. WTF ????????
Any help would be great,
Adam
Adam
