BLOWN Head gasket?
Az671
16
0
1
Arizona
I hooked up scan master and went for cruise around the block. I did two quick burst 20psi to watch readings on SM. I noticed on the way back it started to smoke under the hood. It looked water sprayed from reservoir to the exhaust and had some oil by the passenger wires too. It sounded weird and Temp got real hot 220. Later I noticed water dripping from passenger corner hood insulation. Is RJC HG the way to go?
rag231
1,432
133
63
Charlotte, NC
Are you sure that's a head gasket or just a broken / split coolant line some where? Pull out your dipstick and check your oil for chocolate milk. When I blew head gaskets my first indication was steam coming out of my turbo and filling up my block with coolant. My engine usually blew out inside the manifold towards the lifter area on cylinders 3 or 4.
  • Like
Reactions: Az671
Az671
16
0
1
Arizona
no water in oil but I need to check Radiator for oil.
3.8L V-8 eater
1,361
65
48
48
I would use RJC head gasket or Cometic if your planning on running high boost...I had water spraying under the hood under boost...Started the car crawled underneath and had coolant seeping between the head gasket and the block...
  • Like
Reactions: Az671
Az671
16
0
1
Arizona
Ok, it sprayed toward the battery and turbo cover, but I can see oil on the spark plug wires below the breather.
rag231
1,432
133
63
Charlotte, NC
Did you hear any detonation or back fire when you were getting on it? I had the little "S" shaped coolant hose rub a hole thru because of the way the compressor housing on the turbo was clocked. The black pipe has a nipple that was sticking out too far with that hose connected to it. If you are running a front mount inter cooler the compressor is angled down around 45 degrees. Check that for coolant leaking. If it was your pax side breather leaking oil ( using stock valve covers), coolant could have sprayed from the "S" hose onto the breather.
3.8L V-8 eater
1,361
65
48
48
You would be surprised where all you find traces of coolant when it is seeping coolant like mine was
getchasum
MISSING 2 CYLINDERS???
May 23, 2002
1,980
14
38
52
Morganton, NC
GM Cadillac pills will clean up small seeps but shouldn’t be used to trying to seal a head gasket that’s given up...
Mr.Spool
4,242
535
113
you will be moving the potential damage into the piston area if things go wrong,the graphite gaskets will blow out before cracked pistons, cracked mains, torched deck and head,etc.usually;)at 20 psi the gasket is not holding you back.look into the tune and fuel pressure.
  • Like
Reactions: gunzandgearz
Az671
16
0
1
Arizona
No knock or retard on timing. I got home and coolant leak. I'm going compression test it this weekend.
Az671
16
0
1
Arizona
Yes, that is something I didn't consider. Valid point taken.
MikeS
84
22
8
Stock GM headgaskets for the reasons others stated above. Mine held 25-30psi of beatings for years and when one finally let go nothing else was damaged.
  • Like
Reactions: Az671
Az671
16
0
1
Arizona
Have you done anything to verify that your head gaskets are toast? Leakdown rest? Compression test?
No, it’s been a rough and busy week. I’m planning for Sunday right now. So far I have been pricing and comparing the job just in case.
cruzn57
Still plays with cars!
Apr 18, 2002
4,159
298
83
69
AZ !
if your not using alcohol , your wasting your time, as it will just reoccur, over and over,
and if thats a stock fuel pump, .............well, ..............read the usual recipes for higher boost,
if your in AZ, go see Nick , he can and will advise you correctly.
Top Bottom
