My instincts told me it wasnt a head gasket, but either way, I knew the head needed to come off, even though the car was running and getting me around, sort of.
I've never gotten this deep into my motor, but in 2 hours, by myself with hand tools, I had the heads off and the results arent pretty.
The combustion chambers show very healthy burning and I see no obvious signs anywhere that the head gasket went. Although there are a couple slightly suspect areas (discoloration around the fire ring, but not in an area that aims toward the lifter valley), its not a sure thing. Whoever rebuilt this motor is a moron. He used a big belt sander to surface the heads. You're supposed to use those to surface exhaust manifolds, not heads. But somehow it seems they've stayed sealed...I think. I saw a million heads come into JMS after someone had belt sanded them and they blew head gaskets within 500 miles.
Anyway, the cylinders are wiped out. They show the cross hatch all the way around, except for the piston skirt's path of travel, up and down the top and bottom center of the bore. The skirts ground the cylinder down into a nice oval, except for the top 3/4" or so.
When I grab the pistons and push them side to side, they move ALOT. The cylinder with low compression moves a little more. Im really surprised I was getting 130psi in the othert cylinders, based on what I see. But I see no blown out ringlands, but I do see the rings, right from the top, lol.
****. I cant have this right now.
Engine part donations anyone? lol
