NEW Work Turbo Built 6164 Dual Ball Bearing Turbo. Had this built for one of my builds to accomplish a very fast spool with a small converter and still make 600HP. Reed did a great job, but I ended up changing the combo before he was finished with the turbo. $1000
109 NA Block STD Bore 42k miles, unabused. This should be able to stay STD bore. $500
140 block, freshly machined, 30 over, ready to build but would likely need a cleaning from sitting $250
STD/STD Turbo Crank from 4.1, unabused. This should polish. $250
Turbo Crank, will need rod turned, not sure how much it will need but machine shop said it will go 10. $50
NA 20 bolt oil pan $50
Core Support (good condition) not Aluminum $50
