1984 t-type
Murphy's Law
So my BLMs were stuck at 142 after changing out to a new FPR, before hand they were right at 128. I did some searching and saw a mention of maybe adding more base fuel pressure and decided to give that a try since I was certain I had no vacuum leaks. So I bumped the pressure from 42lbs line off to almost 50lbs line off and reset the ECM now my BLMs are back at 128. So I’m curious as to what this is telling me since most would put a high BLM issue on a vacuum leak, just trying to learn and get more of an understanding of what’s going on in they system. I want to get my knowledge and understanding of these cars to the point where I’m the one answering questions and not always just asking them.
Oh and by the way I set the fuel pressure to 42 line off just because that’s what I have always read and done but after I switched to E85 the other year I bumped it up to around 50 line off per recommendation of a member here can’t remember who to help with an off idle stumble I was having and it worked.
