I just wanted to share a problem that I've been having lately. My car has devolved a miss fire under high boost. This results in it popping back through the intake. The last time that it did this, it popped a couple of times and then had a very loud violent boom! This in turn blew both head gaskets on #3 & #4 cylinders. My wide band looks good and it's not getting any knock at the time that it starts miss firing. What I believe is happening is the ignition system isn't up to par and Isn't firing the plugs every time under pressure. This results in unburned fuel/alcohol in the combustion chamber. When it pops back in the intake, this gives it boost spikes which in turn makes it spray more alcohol which makes the miss fired combustion chambers even richer. The plug finally fired and all of the unburned gas/alcohol went boom. I'll also add that every now and then, at light throttle cruising , the car will miss fire very briefly then resume back to normal. When the light throttle miss fire occurs, it drops all cylinders, like briefly shutting the car off and back on again. Has anyone ever experienced these problems?
