Coelacanth
- Jul 7, 2014
Hi guys,
I bought one of the billet vacuum blocks from Kirban Performance, there are 2 kinds: #6796, and the one I chose, #6797. I polished it up really nice from the original machined aluminum finish.
#6796
https://www.kirbanperformance.com/product/128/VACUUM+BLOCK+#6796.html
#6797
https://www.kirbanperformance.com/product/129/VACUUM+BLOCK+WITH+EXTRA+VACUUM+FITTING+FOR+VACUUM+BRAKES+#6797.html
I chose the one with the extra vacuum fitting as I will do the vacuum brake conversion eventually. I figured the 2 blocks were otherwise the same.
When I got my stock vacuum block off, I noticed the porting on the billet block was significantly different than the stock plastic block. The front port hole ahead of the front-most screw hole is totally missing/blocked off on the billet block. Is this normal? I don't want to install this unit if that missing port hole causes problems. It *does* look like the main middle port channels through to all 4 vacuum line fittings, but I just want to be sure before I go ahead with this.
#6796
#6797
