Nice back half.lots of room on the 60ft with that mph.Finally got to the track. What I expected at 21# of boost.
1.989 (2000 rpm at line)
5.143
7.757
94.00
10.012
11.913
119.04
1.628 (4 psi at line)
4.687
7.278
94.90
9.530
11.438
117.97
If you have a good tire on that car.high 1.4 s to low 1.5 s can be had withh that mphOh yeah there's a 10.9X in there. With a better tune & more boost my plan is 125 thru the traps. What's really helped is leaning out first gear.
You got a nice combo, If you don't mind me asking, what rpm are you crossing the finish line at? Look forward to seeing how much you get out of the 5957.Bisons Performance Description: TE MFS 5957
109 30 over, champion Al heads and intake, 212 212 cam, jimmy trans, PTC 9.5, Alky, LS1 MAF, 60s, racetronix pump and injector harness both hot wired, bit a rear suspension, TT chip, CAS V2 FMIC
Tuned on a NB and monitored with a OTC2000
With that combo you could use a larger turbo I think.
The PTC is giving good slip numbers.With my 12" LU 5700. Now with the 9.5" NL 5500. Both on a 26" tire.
Now that's the goal, how much can I squeeze from the 5957! It's fun on the street.
Is that with a 275/50 MT ? have you ever slapped on a set of 28"s and did the run?With my 12" LU 5700. Now with the 9.5" NL 5500. Both on a 26" tire.
That's a lot of motor.Bisons Performance Description: TE MFS 5957
5.143
7.757
94.00
10.012
11.913
119.04
4.687
7.278
94.90
9.530
11.438
117.97
How much does your car weight with driver? Hopefully I'm tuned next summer and can start gather some time slips with my 62/65 and 3800 car. My goal is 10.5.Finally got to the track. What I expected at 21# of boost.
5.143
7.757
94.00
10.012
11.913
119.04
4.687
7.278
94.90
9.530
11.438
117.97
5.143
7.757
94.00
10.012
11.913
119.04
4.687
7.278
94.90
9.530
11.438
117.97
Good times for a "heavy" car. I'm surprised I got into the 11s with my TE44, given the weight of my car. I did have a full tank of gas when I weighed my car though.[emoji651]️ 3710
