best place to buy?
Check out www.kirbanperformance.com for the rag joint or his upgraded steering shaft that has u joints and uses no rag joint.
You may want to post a parts wanted add in the marketplace section for the specific front sway bar you're looking for.
I would buy a jeep steering shaft and just ditch the whole rag joint . You will notice the steering tighten up if u do the jeep shaft .
