regalman4925
- Feb 27, 2015
Does anyone know of a better seat cover kit than the highway stars exclusive kits? They appear to be the closest to factory out there from what I have seen. Thanks
We purchased these a few months ago and recovered the seats ourselves. Tip for you..have some carpet padding and some of the adhesive handy or something similar as you may want to use it to stuff in certain areas to cover some sharp parts of the steel on the existing seats and to fill some areas where the existing pad has worn down over time. We did this and the more we added the better they turned out. They are more large than small which is good for the recovering process. Good luck !
YES..SMS at last check was about $100 for a square yard if I remember correctly.
Yes, I bought the seat covers and the matching door panels. The material does seem a bit thinner but they are very nice. I really do not think the thickness will have cause any issues. I did reuse the foam that was stitched into the back of the originals. I cut it out of the originals and used it behind the seat. I did everything myself and they came out great. The headrests are a bit loose so I need to add some foam into them to tighten them up.Did you get the interior parts?
I am wondering what to go with. The shiny stuff (Exclusive) seems thinner than the Pallex but then our cars are typically no longer a daily drivers.
Do they have the Exclusive material for the upper door panels and rear inserts? I looked but do not recall seeing it.
That is funny. $75 a seat is a very good price. I hope they do a great job for you.
