baer 12 inch zr1 corvette brake kit for Gbody
cjmatt
Moderator
comes with all rotors, calipers, hardware, and stainless lines
This for fronts only btw and will fit under 15inch grand national wheels
$400 shipped
Is everything included thats needed to install this? Do you need to change spindles, control arms, prop valves, etc?
I have the LS1 brakes and the stock 85 rims rub bad! Not sure about 86/87 wheels. I would check around first. Unless your ready to buy new wheels like I was.
ls1 calipers are alot larger than zr1 calipers height wise, these will fit under the stock 15 inch wheels
Do you have to swap anything else out at all? Or can you simply throw these on and go?
you just need the baer mounting bracket, its like a boomerang looking bracket, you could prob make it yourself if you wanted, then just need to have your stock rotors cut down and these slide over since there are no hubs
