So when I go to build boost most of the time the car will backfire out the intake. I put on a different maf that I got from a board member here and the car ran way better. It would stumble at idle before. When I look at my scan tool my maf,int,blm,tps all seem to be doing what there supposed to. As far as running lean and rich and all that stuff. The car is stock except for a tt chip, fuel pump hotwire and afpr. I'm thinking maybe it's an ignition problem. Car has brand new plugs and wires just factory stuff. I was wondering if maybe I should. Pull the plugs and see if one looks off. What would you guys be looking at. I can ease into it and build boost most of the time but if I floor it it will backfire usually around 10psi. Any pointers would be greatly appreciated.
