ARP studs for TTA heads.
Grumpy
Thread killer
dont think they have a kit. I had to order by the lengths of the bolts. this was years ago.
proptop
Turbo T231,
Let me look and see if I still have the lengths in the shop. In addition there are three along the bottom (both sides) that we had to chuck up in a lathe and cut them down. My buddy just sold them along with a set of heads to a member on here. Maybe he will see this post and measure them for you.
Thanks,
Bob
BEATAV8
The Engine Whisperer
TurboT231
Turbo T231,
Thanks,
Bob
Sounds good. Thanks
chopped39
Call Arp. I did and talked to the engineer . They do not make a kit for TTA heads. If you want to cut your headers and not run a washer you can but they said you have to use the washer. I got screwed by RJC. They sold me a kit that they said they worked with ARP to make. Crock of shit.. Arp told me to use the stock factory bolts. I ordered 8 ARP bolts and milled the head down and they just barely fit with the washer. I left the studs in the other holes. That picture that BEATAV8 posted is my engine
proptop
Gents,
Found my notes/box when I made these for my Buddy. Disclaimer I don't have access to them now as they have been sold. I used 7/16 fine threaded 11/16 socket headed nut that measure .450 in height with a diameter of .780. Top of studs were 7/16 - 20 (fine) and the bottom are 7/16 - 14 (course). Also you can use washer under all of the studs except the ones/three along the bottom next to the exhaust tubes.
4 studs are 5.250
4 studs are 4.00
8 studs are 3.00 and you have to cut the Broach out of six of them to clear the exhaust tubes.
Hope this helps.
Bob
LSTTYPE
Hey guys I think that was me who bought those heads and custom studs. I haven't been on here in awhile.
Remove Ads From TurboBuick.Com
Yearly amount needed to remove ads from TurboBuick.Com
Goal
$12,000.00
Received
$2,246.00
