Anyone Running Walbro 255 On E85
Hahny
I would like to know if anyone is running a Walbro 255 on E85 and what would be the maximum HP with this set-up? Thanks
Friend of mine has. As for as max power that will very car to car.
Thanks Boost231. I just found out the other day that my local gas station is now carrying E85 and I am thinking about converting my fuel lines over to Teflon. That being said, I just replaced my old fuel pump over the winter with a new Walbro 255 and hotwire kit and I was hoping to keep this pump when I do convert the car over to E85. Just trying to save some $ considering the new Teflon feed/return lines are going to set me back about $500.00.
I've been running e85 for 3 years with stock lines with a Walbro 255. I did upgrade the soft lines outside and in the tank to E85 compatible lines. Still running the stock turbo and 22psi.
Sent from my XT1650 using Tapatalk
I have read somewhere about guys running flex fuel sensor with E85, due to E85 being inconsistent from one location to the next. Are you all running a flex fuel sensor? Thanks
The E-85 in South Florida is mostly E-75. I have been running it for years @ 28# Of boost no knock 21degrees timing
I'm running an SD2 chip with a flex fuel sensor so it adjusts timing and boost based on ethanol content
With a 255 pump I would really like to know what your duty cycle is like at 20plus lbs of boost. I can almost guarantee it’s above 95%. If anyone was replacing a fuel pump and know they are going to run e85 I would look a the walbro 450 or a detuchworks pump . I guess it’s just me and not like running on te hairy edge of something goin south . Also you it would be wise to go with at bare minimum 80lbs hr injectiors .
Have you zeroed out the timing to ethanol content section?
No. I decreased the amount of boost it was adding but otherwise the ethanol tables were left as delivered
I would zero that out unless you like adding 4-6* of timing
Yeah, I'm around 95% at 20 lbs of boost. I'm currently running 60 lb injectors along with a walbro 255 and was hoping to keep those when I convert over to E85, but you recommend 80's?
