Anyone ever try to paint the ratty looking firewall
Dhos1
Self-tuning wanna-be
I was looking at my engine firewall and it looks kind of ratty. Anyone try to paint it with the engine in. Possibly spraybomb it.
NY Twin Turbo
All the good stuff.....Times 2.
Claude is right.
But you can clean it up quiet nicely if you are supper detail orientated. First it needs to be clean. Start by removing as much as possible, coil pack, wiper motor, ground wires, wiper actuation rods, cowl weather strip, maybe the lower windshield trim, or anything else you can depending on how far you want to go.
Then use aluminum foil to tightly wrap components, masking tape, old towels to shove into spaces, newspaper, you know the deal. Use semi gloss black. it will loose some of its sheen over time. Don't use gloss unless you want it to look absolutely ridiculous next to the rest of the shit that is 30 years old. By the way......you might as well take every other accessory of the engine and clean detail and paint it as well.
Or take the whole car apart and clean everything with a q-tip and toothbrush and then paint it.
What's the difference? You may not be going anywhere for a while. I know I'm not.
KC87
Claude is right.
Lets not go overboard, never know if you might have to throw the bug out bag in the trunk and the pup in the front seat to get out of Dodge in a hurry. Notice I said the pup and not the Mrs. :LOL:
NY Twin Turbo
And where will you go? Mars?
Speed Demon
I originally did the top part of firewall while engine was in with the Technic like Twin Turbo suggested then when the motor was out I did the rest. I would recommend using Satin black it has a little less sheen than semi-gloss.
Also if your plastic fender wells look kinda brown, spray some No Touch tire shine on them let sit a little then wipe where you can. They come out looking new.
Reedogg
Just did mine. Engine was on the stand though. Wouldn't attempt with engine in place.
Pronto
Believe nothing you hear and half of what you see.
With the car in a spot you can work on it and the engine cool, wrap everything up in foil and plastic. Spray down the firewall with degreaser and scrub where you can. Lightly spray it off, hit it with the exhaust output of a shop vac to blow off the water from the nooks and crannies. Wrap the rest of the front of the car with plastic including the windshield. Spray it with the paint you choose. I didn't paint my firewall since it's silver and was just dirty not peeling. I just cleaned it best I could. Once the engine was out I did better job but you can do a nice job with the engine in. I remember there was a post by someone that had a rough looking engine compartment and went through it without pulling the engine and it looked fantastic.
GNRick
Retired member
I used POR15. Applied it with one of those sponge brushes on a stick. Actually came out looking pretty good!
