Another powerlogger file..my first!
Heskahoka
Supporting Member
Hi All.
Just logged my first run on my 4.1 motor using Powerlogger. I am new to the tuning of this car, so I am open to suggestions.
Some info on the run:
-Engine has about 200 miles on it.
-98 octane in the tank.
-Max 15 psi.
-TT 6.1 chip.
-Alky system, but not powered up currently.
Thanks for any advice.
-Mike
  • First run.dat
No knock, low 800mv's, looks good to me.
Need to tie in the map so you can read boost.
Next time try and keep the pedal on the floor.
Rick
Agreed...everything look fine. Like Rick says...a WOT blast would be more telling.
Good advice guys, thanks.
I need to check the MAP sensor connection to the Powerlogger to see why there is no data.
I will also try to 'baby' the car less and really record a real WOT pass.
