Back in the game, and need a little advice...
ONLYAV6
I've been noticing for a little while the alternator not charging to what it's supposed to after ordering a new alternator still not charging. I bought a new battery still same thing not charging to where it's supposed to be and, then I noticed these two wires were not connected and one of them was completely melted. Does anyone know what these wires are for and could this be my issue.
Okay I figured out the one it was to my O2 sensor I don't know how the car didn't run funny or check engine light didn't come on but what is this other wire to that was melted I don't know where that goes
Here is the picture maybe somebody can help me out and tell me where this goes
the 4 pin plug is not stock , as far as i know is for a heated o2 ,
the rubber plug is for the oil idiot light and the fuel pump feed when oil pressure is above 4psi . its often disconnected and the sensor removed when adding an aftermarket oil pressure gauge , just make sure the terminals dont come in contact with bare metal or to each other , you could cut plug off and tape the wires up to prevent accidental grounding or shorting
now on to your issue with alt not charging ...
Does the volt light in the dash come on with key on i run position engine off . it should be on .. without the lamp the alternator isnt exited and wont charge
if bulb is not there with key on , make sure the one wire plug (brown wire) at rear of alternator is plugged in , if its plugged in you need to fix the bulb issue in the dash or issue in the brown wire but its usually a bad bulb or bulb socket contact
you can also get a casper field fix that will allow the alternator to charge even if the bulb doesnt work
