Looks like the alternator is going. Using a DVOM on the back of the alt, it shows like 10.8v and about that at the battery. What do you guys recommend as a replacement? I have Autozone, NAPA and O'Reilly here locally. Would having the stocker rebuilt be a better choice? Any way of having to built to put out more like 14v? Reason for checking is the Scanmaster was showing 10v at idle with everything off.
Thaks in advance!
ps...if the voltage is checked at the stud in the back of the alternator...is it pretty obviously a bad alternator...or do I need to check other things first? I'm an electrical dumba**
Thaks in advance!
