Two possible scenarios. First scenario (most likely) is that the connection to the sensor is lost or the sensor opens up internally, at which point the air temp reading drops to a little below 0 degrees fahrenheit, making the car very rich. Other scenario (not common) is that the connections to the sensor or the sensor itself shorts together, resulting in a 255 degree inlet air temp reading, resulting in a lean condition.
