Air temp sensor question
Craig Smith
That was easy!
Two possible scenarios. First scenario (most likely) is that the connection to the sensor is lost or the sensor opens up internally, at which point the air temp reading drops to a little below 0 degrees fahrenheit, making the car very rich. Other scenario (not common) is that the connections to the sensor or the sensor itself shorts together, resulting in a 255 degree inlet air temp reading, resulting in a lean condition.
1st and goal
Craig,
Thanks, ;) was just looking for confirmation of scenario #1.
I have to get a new air temp sensor as mine is MIA after a dyno pull when the intake tube blew of the throttle body after the t/b blades closed.
Is it necessary to replace it with a GM sensor or is a sensor from a local auto parts store ok?
Marc
1st and goal
Pay no attention to Brady cause as you know he's from "LA" = Lower Alabama :p
So does the type of air temp sensor matter?
Nope, don't know you but appreciate the wisdom :)
Uncle Marc
Otto J
Bad air temp sensor will make the car way rich. My car was tuned mint and then one day if felt slow. so i hooked up the laptop and found my air temp was way off and my a/f was 9.79 to 1 took out the sensor and it was gone(the guts) replaced it problem gone.
Otto
