V Vertigo107 Member Joined Oct 13, 2008 Jan 24, 2010 #1 Whats the best/easiest method to remove air bags when changing springs? Thanks!
T TURBOTWIN2 ASE CMAT L1 Joined Jun 17, 2005 Jan 24, 2010 #2 Easiest way? Just leave them in the old springs after you install the new springs! Hey, you asked. Squeeze as much air out as you can, fold it over a little bit and then slip it out through the side of the coils.
V Vertigo107 Member Joined Oct 13, 2008 Jan 24, 2010 #3 TURBOTWIN2 said: Easiest way? Just leave them in the old springs after you install the new springs! Hey, you asked. Squeeze as much air out as you can, fold it over a little bit and then slip it out through the side of the coils. Click to expand... I did ask! :biggrin: Thanks, ill give it a try!
V Vertigo107 Member Joined Oct 13, 2008 Jan 24, 2010 #5 I got them out by squeezing the air out and pulling them through. Thanks again!
