aggravated
tdd
I'm about aggravated with this car ,was experiencing fuel pressure drop on boost started getting knock at 12lbs looked at log dipped 10psi fp got a new pump changed fuel filter did it again around 19lbs inj was 90%dc af are all over the place cant tune it like that about to give everything a once over
mods are
6262 turbo
60lb inj
champion heads and intake fuel rail
racetronix 255 fuel pump any suggestions would help
Battery voltage readings?
Pump voltage?
Screenshot of the log?
What Chuck said. I'd prolly remove the tank and check the clamps are tight.
Injectors could be clogged up, fuel filter probably needs to be changed.
I guess it has a "hot wire"?
Try running an extra ground wire from the fuel pump harness back to the battery.
Change in tank connector hose, when you did the pump?
hose and pump is new
source voltage was 12.2
available at connector with pump unplug was 11.93
voltage with pump plugged in probed was 10.23
Time to fix that voltage issue
