Aem boost gauge controller
joeb1300
TurboBuick.Com Supporter!
Can anyone tell me if i can use this aem true boost controller with a tt chip stock ecm? Running on e8t if that makes a difference .
Sorry yes E85. The aem gauge has a boost controller built in to the gauge . Wondering if the different levels of boost would cause the engine to run lean or rich..
here is a link
AEM 30-4350 - AEM Tru-Boost Gauge Type Controller
AEM#017-30-4350
Tru-Boost Gauge Controller
  • 2-1/16" (52mm) Housing
  • If you find a Company with a lower advertised price on the same item we will match it
  • Just give us the total "To Your Door" delivered price including all shipping & Handling Charges
  • Quick Price Match Confirmation and immediate processing
How to Price Match
XXXX.XX Skip Price Match
AEM's Tru-Boost Gauge-Type Controller is an electronic boost controller that combines the simplicity of a manual boost controller with the added ease of adjusting boost levels through a gauge interface. There is no external interface required for setup, and it is fully functional right out of the box. There are no gimmicks or special software programs included. If you want more boost press the button on the right of the gauge face, and if you want less boost press the button on the left of the gauge face. It's that simple, and IT WORKS!
The controller includes everything you need, including an onboard 29 psi pressure sensor, built-in Overboost protection with two timed shutdown levels, a scramble boost setting and a low-side output for a warning light. The included boost control solenoid is the only one specifically manufactured for automotive boost applications, which means it won't corrode and stick from exposure to rich fuel mixtures (it is pressure tested to 100 psi and includes -4AN fittings to eliminate any chance of leaks).
Features
  • Complete system includes harness, boost hose, onboard 29 psi pressure sensor, boost solenoid, gauge display & all necessary fittings
  • No external interface required for programming!
  • Two user-selectable boost settings with peak boost memory
  • Scramble boost setting allows user to momentarily change boost levels
  • User-selectable overboost alarm includes two timed shutdown levels at 10% and 20% overboost
  • User-configurable gauge has 24 scalable LEDs, interchangeable bezel, pin guide, and faceplate to customize look of display
  • One low-side output included for warning lights
  • Quick connect technology simplifies installation process
Russell 670550 - Russell AN Male to Metric Male Adapter Fittings
Only $9.99
Ships Today
2-1/16" (52mm) Housing' type=hidden name=comments1>
I was shopping on JEGS.com and thought you might be interested in this.
- {0}" type=hidden name=emailText> Your Name
Χ
Your Email Address
Χ
Recipient Name
Χ
Recipient Email Address
Χ
✓Send
JEGS Performance Products 28011 - JEGS Thread Sealant
Only $5.99
JEGS Performance Products 41085 - JEGS Aluminum Gauge Panels
Only $19.99
