Add on seal for c clip eliminators
Waco84GN
Member Boost-aholics anon
I did the search feature on the board and found a number 28X55X8DL which basically means 28mm id x 55mm od x 8mm high and double lipped. This part number is basically impossible to find even at the local speciality bearing and seal shop.
Anyone know a common "part store" number for a seal that will work in this application.
If not, can you point me to a source to purchase this elusive seal.
Thank you for your help,
Jerry
The closest I could find was 28x56x8ADL which in TCM brand would be 28x56x8TC
It is a little bigger on the OD, not sure if you would be able to get it into the housing.
thanks for the reply. i dont have the diff torn down yet but figured i would try to have the needed parts before i try to go in for the job.
thanks,
jerry
