ac dont work
TexasT
Texas, Where are you from
Sep 10, 2002
4,590
374
83
117
Texas
ihadav8.com
did you try unplugging the switch and using a jumper to get the compressor to start? I did that to get the thing to go after it had sat a while.
TexasT
Sep 10, 2002
4,590
374
83
117
Texas
ihadav8.com
I guess I should ask if you have gauges and if the system has pressure in it. Does it have a 134a conversion or are you running r12 still?
gsgnnut
398
62
28
55
With car running a.c. control on max Check power to a.c. clutch unplug the pig tail to clutch and measure with vol. If you have 12 v. And sufficient pressure in system the clutch is
ng. If no power relay is usual suspect but check for gnawed wires.
Top Bottom
