A thread of pictures
T- Type Tim
Vice Chairman
T- Type Tim
Vice Chairman
Give Scot a holler at gns
He hooks up board members pretty good
Fixin to order a set of front coil overs here pretty quick
T- Type Tim
Vice Chairman
A re spring was needed. I went from a 12" 110lb spring to a 14" 150lb spring. Now i dont have to crank up the preload to set the ride height.
SCOOBY DOO
I'M NOT A MONSTER, I'M JUST AHEAD OF THE CURVE!!!
275/60/15's on a rim with a 4 inch backspace will clear the frame and wheel lips with ease.
haywire4130
Iirc those are 275/50/15 mt's on 10 inch wide jegs rims. Those tires run really wide and measure almost 11.5 inches (my buddy has them on his cobra). I remember all the numbers cuz i was planning on ditching my gta wheels for the same setup for street duty
SCOOBY DOO
Take a look at the pics. Fairly certain on the inside of the tire it says 275/60/15.
haywire4130
So it does... on the jegs wheel thread a couple months ago there was him and a brown one, the brown one was running 50's. But theyre still 10" wide rims, they look mighty close to the lips
I'm running 60's. You really need to make sure the rear end is centered. Roll the fenders and I would recommend coil overs.
SCOOBY DOO
Rear end in my car isn't centered...and I use 275/60/15's and 28x9 slicks on 8 inch rims with a 4 inch backspace and they fit no problem.
T- Type Tim
Vice Chairman
yup they are rolled...the deal with these rims is they only make them in 4.5" backspacing for the 10 " rim......they are real close
thanks for the compliments fellas
dank GN
BlackArts Automotive (661)993-8277
Here is my rear end . Eaton true trac with 30 spline moser axels and C clip eliminators . I also welded the axle tubes to the center section . I fit a 10.5 x 28 x15 without a frame notch . Just need airbags to stiffen the rear up or else it would rub the inner fenderwell . I also have the s10 7/8” brake upgrade and a TA diff girdle
