J ~JM~ Wrinkled Member Joined Oct 31, 2007 Jan 30, 2018 #1 OK all you H&R Bar owners. What spacing did you select for the axle tube mounting brackets? Narrow, or wide? Any other installation/adjustment advice is welcome. Thank you.
B Boost231 What's An Intercooler Staff member Joined May 26, 2001 Jan 30, 2018 #2 Wide as you can get Sent from my SM-G935T using Tapatalk
J ~JM~ Wrinkled Member Joined Oct 31, 2007 Jan 30, 2018 #3 Boost231 said: Wide as you can get Click to expand... That was my plan. Just wanted to make sure my plan was sound. Thanks.
J ~JM~ Wrinkled Member Joined Oct 31, 2007 Jan 30, 2018 #4 Another question. Easier to install with rear suspension at ride height, or at full droop?
dank GN BlackArts Automotive (661)993-8277 Joined Jan 11, 2009 Jan 31, 2018 #5 Better to install at ride height so you know where it is going to live also you want to put alil preload on the passenger side after it’s all set
