86 gn wont run
hotairgnx548
hotairgnx548
A vehicle with a new fuel pump (someone installed). At first would not run coil pack a module now running fine for a couple of weeks. Then it quit one day. Fuel pump not running.Unplugged hot wire and hooked it up with stock wire. Would not run. put 12 volts to the prime wire and runs fine. Of course you cant drive it like that because the pump runs all the time. Any ideas? Thanks John
