J ~JM~ Wrinkled Member Joined Oct 31, 2007 Nov 14, 2017 #1 I had the clearances, back-lash & torque specifications saved at one time. Unfortunately the link is dead or missing. Anyone know where that information is available at this time? Thanks.
czimpel Boost...gotta get some! Joined Aug 16, 2012 Nov 15, 2017 #2 http://www.crawlpedia.com/ring_pinion_setup.htm
J ~JM~ Wrinkled Member Joined Oct 31, 2007 Nov 15, 2017 #3 czimpel said: http://www.crawlpedia.com/ring_pinion_setup.htm Click to expand... Great! Thanks. http://www.drivetrainshop.com/GM_8_5_8_6_s/112.htm I see two 8.5" listings. Listed as: (2-Cut) & (5-Cut) Which one of the two describes the TR rear axle?
czimpel Boost...gotta get some! Joined Aug 16, 2012 Nov 15, 2017 #4 I believe the 5 cut. I usually run the backlash at .006-.010, so that is what I usually use.
J ~JM~ Wrinkled Member Joined Oct 31, 2007 Nov 15, 2017 #5 czimpel said: I believe the 5 cut. I usually run the backlash at .006-.010, so that is what I usually use. Click to expand... Thanks again.
