'72 Buick Skylark Custom
Trader history for '87 Turbo "T" (0)
'87 Turbo "T"
What a complete shitshow!!
Putting my 1972 Buick Skylark Custom for sale. Need to free up some garage space. Lifelong CO car. Originally a 350 car. Asking 13k OBO.
I have put a good amount of work into upgrading(a bit) and trying to bring it a bit more into modern times. Body will need some TLC but not a rust bucket. Will need new lower fender patches. Floor and trunk are solid. Core support is also very solid. AC car however, I removed it. Still have all of the parts to reinstall.
Interior is in good shape. No cracks in dash pad. Everything works. Radio, clock, rear defroster, & map light. Has front bench seat that will need to be recovered and new foam. Headliner is in great shape. Rear seat & tray are in great shape. Door panels are in great shape. Driver side will need a new armrest pad. Carpet is in good/decent shape.
New vinyl on roof. Only two minor holes needed to be filled in. Roof & lower window area by trunk are solid. Roof is completely rust free.
I have documentation from Sloan/Longway. I also have found one of the build sheets. Have the dyno numbers from the build as well. I also have the original temp tag from 1972. Also have the GM service manuals & the assembly manual. I’m sure I missed something but I think I’ve covered most of it. I have all of the paperwork, build receipts, & can answer any questions.
Serious inquiries only & I don’t need any help selling. DM me for more info. Have 30-40 pics but with the server issues I can't load here.
Kyle
Engine:
Mildly built 455 bored .30 over. All TA internals.
Forged rods & pistons
Stainless steel Stage 1 valves
New rocker arms/rockers
Mild work done to heads(have flow numbers)
Stage 1 fuel pump
TA front cover
TA high flow water pump
Stock headers (Cerakoted)
Rebuilt Quadrajet & distributor from Ken at Everyday Performance.
New Dewitts Aluminum radiator
New fan clutch
All new hoses/belts
New battery/tray
Rebuilt alternator
New true 2.5” “H” pipe exhaust into dual Flowmaster mufflers
Front suspension:
Totally rebuilt front suspension.
New Moog upper & lower control arm bushings
All Proforged steering parts(Tie rods, center link, idler arm, etc)
Rebuilt quick ratio steering box
New rag joint
Moog springs
Bilstein shocks
UMI 1-1/4” sway bar & bushings
Transmission:
Rebuilt TH350 with Jim Weise 9.5” converter flash 2,800-3,000k stall
Derale 51606 trans cooler
Aeroquip pushlock hoses & fittings
Rear Suspension:
Rebuilt 8.5” 10 bolt. Hot tanked, blasted, primed & painted satin black axle.
28 spline axles
3.42 gears
Detroit Tru-Trac posi
Motive gears
Timken bearings/seals
Moog cargo springs
Bilstein shocks
Stock upper control arms
UMI boxed lower control arms(stock bushings)
UMI 1” sway bar
Brakes:
Right Stuff front disk conversion
New calipers
New booster & master cylinder
New proportioning valve
New brake lines to both calipers
New brake line from valve to rear
Slotted/vented rotors
SS brake lines on rear axle
Rebuilt drum brakes
Interior:
Interior overall is in good shape.
Rebuilt clock(quartz converted)
All interior LED bulb conversion(minus map light & glove box)
Re-cored original heater core(done by local radiator shop)
Body:
Body overall is solid.
Will need lower fender work
Some surface rust & patina
Floors are solid
Trunk is solid
All original glass
New roof vinyl
Wheels:
15x7 rims up front
15x10 rims in rear
New Cooper Cobras less than 500 miles
245/60-15 up front
275/60-15 in the rear
'87 Turbo "T"
'87 Turbo "T"
More pics if anyone is seriously interested. Not going to use up all of the TB bandwidth:p!!
