I talked to him 2 days ago and he said it was 27 psi with the 3255 and about 25 with the 6262. He used one of my TT chips and bumped the timing a couple degrees in all gears i think he said 24 degrees. It was still a little fat imo. But no wideband so hes staying safe.Thanks man, what kind of timing and boost was he running? It sounds like a nice turbo.
TE60/.63 garrett hsg, champion irons, champion intake, 206 roller kit, 60's, TT chip, Razor's alky, Ls1 maf/T+, Mease SLIC, THDP, Janis transmission, Precision 3200 5 disc l/u converter, stock bottom end, 516rwhp/555rwt @23psi, 562rwhp/578rwt converter locked, assembled and tuned at KDK Performance Orlando Fl.
Brian,
I need this!!! I need some boys from the Con to put my junk together!
Are we special in CT or something?:biggrin: Ill be in Orange county CA in feb or march. Still far from you though
A single state that contains both you and Otto and you have to ask if you are special!? :wink:
Conneticut is a small state.... I'm suprised it can hold the both of them!
:biggrin:
:biggrin:
Man I need to get my junk together!!!
