4140 ground adapter plates for oil pump and Johnson lifters on sale
bison
Moderator
Staff member
TurboBuick.Com Supporter!
$425 per set for v6 reduced travel. $455 per set short travel.
$50 for adapter plates
For quantity breaks message for more info.
What's the difference between reduced and short travel?
The short travel will get the most possible out of a hydraulic lifter but the preload must be set very accurately. Almost identical performance to a solid but a little heavier than a solid.
what is the difference between this plate and the kenny bell style oil plates?
These are ground flat, steel, and don't require modifying the adapter. Also has the slot to minimize debris scoring the gears and plate which KB does not have
