4" MAF pipe with 85mm Z06 MAF with wiring adapter
Steve
I have a 4" MAF pipe with a 85mm Z06 MAF sensor that I want to sell. The MAF pipe was bought in the mid 90's and I think it came from BGC. The pipe is steel and is painted black but it could use a fresh coat of paint just from normal scratches and wear. The pipe has a threaded bung for the IAT(IAT not included). The pipe does have a small dent in the area where the IAC connector goes for clearance. The MAF sensor is a 85 mm Z06 MAF and it does come with the 5 to 3 wiring adapter so that the MAF will plug into a translator. The set up comes with two 4" straight couplers and 2 4" t bolt clamps and 2 regular 4" clamps. I will also throw in a large 4" K&N come filter. If you have a 4" inlet turbo this should get you what you need from the turbo to the filter. $200 shipped in the 48 states(please add 3% if paying with paypal)for the pipe sensor and wiring adapter.
