i use the stock plastic elbow...even though i dont use the air temp sensor bc of my chip...but like it plugged in still....i also like these silicone hosese for other application... and use a hard joiner pipe like pvc or metal...
HPS 3" OD 6061 Aluminum Joiner Tube Piping with Bead Roll
HPS 3" 76mm 6061 Aluminum Straight Joiner Pipe Tube bead roll 16 Gauge hose connector ideal for diy custom 3 inch cold air intake kit, radiator heater coolant hose, turbo intercooler pipinghpsperformanceproducts.com
really ...wow you have stock maf hose ??? they are pretty flexible ...grind it down or cut it off...I purchased one of these and I cannot get the 3" hose to fit over the rib on the end of the connector.
Things I have used back in the day...........I purchased one of these and I cannot get the 3" hose to fit over the rib on the end of the connector.
and it all will work ...my man ...hows it goin joey...any light at the end of the tunnel yetThings I have used back in the day...........
Shop vac connectors for wood shop vacuum set-ups. An old leaf blower tube hacked to length. Old aluminum light post for you home's front lawn.
Like many others, lot's to stress over right now. I've been here, not posting though. Just mostly lurking.and it all will work ...my man ...hows it goin joey...any light at the end of the tunnel yet
