3.40 steel crank, scat or k1 rods, stroker kit, roller cam, morrel lifters, 3.42 gears
threerail
need these parts, new or used.
3.4 steel crank
scat or k1 rods, 5.96 or 5.97 with .940 pin size
roller cam, would like a billet comp 212/ 212, or similar to this would be considered, lmk what u have, also would consider iron roller cam with similar size, lmk
morrel roller lifters
may go with a stroker kit instead, contact me with what u have please.
3.42 gears for 10 bolt 8.5 axle
thanks guys
3.4 steel crank
thanks guys
I have a set of 3.42 gears, crown & pinon $150.00 ship to your door.
killer, are these gm gears or aftermarket?, how much use?, or new? etc...details please, thanks
DLS Engine Development
886 E 900 N
Wheatfield, IN 46392
(219) 956-3653
Dan was the "engine" in Precision Turbo and Engine for years.
talked to DLS about crank options, may go this route, Dan was real helpful about my options...
post up if you have these parts to sell....thanks
I've got a set of original GM 3.42 gears from my 1980 Z28. Only reason I swapped them out was to go to 3.08's to drop the revs for better gas mileage. $125.00 shipped to your door.
