200R4 behind an LS
In case anyone is interested.--Lee
One of these days I will do mine like that been going on 3 years now---yours looks super.
I've had a "Jake built" 200R4 / LS1 in my '72 Maverick since 2009. Flat flexplate and a $45 spacer and it bolts right up (minus that one bolt).
The pictures don't do justice for the amount of time and work that Lee has put into this project.
Is there a production throttle arm adapter for 200/700 applications or was it custom built?
Not production--just a short piece of tubing with a washer welded on the end -the other end welded to the shaft--I did use the arm which I assume is for cruise--repositioned it and also made the bracket that bolts to the head. I am useing a 87 GN cable as my original 87 442 cable is too short. I used the measurement from the bracket base (87 GN). to the hooking tab and duplicated that so my min . TV was .840 of valve sticking out of VB and completely buried @wot.
