200-4R manual VB operating temps
PonchoMan
Does anyone have normal temp readings for a 200-4R with a manual VB? Finishing my build and want to do some benchmarking. Thanks in advance!
Mine runs between 140/200 full bullet internals and aftermarket pan
And if its really warm out say around 90 I run around 190 /230
Don't know if it is but it also has a trans brake ( haven't used it yet) been foot braking since I put the hydroboost in
It has more to do with load and how much slip you have in the converter. All the heat is generated in the converter. The more efficient the converter, the less heat you're going to have to deal with. The rest of the guts don't really matter that much.
All that said, you want that fluid below 200F.
