200 4R 1-2 accumulator delete kit
olds403
107
0
16
Visit site
Z plate - gasket - plate - bolts
You can do the same with a plug in the 1/2 for .50cents. This just makes it cleaner and removes it all
TexasT
Texas, Where are you from
Sep 10, 2002
4,589
373
83
117
Texas
ihadav8.com
Disabling the accumulators takes the cushion out of the shift. The trans will shift quite violently without the accumulator function, especially with elevated pressures and a full tv. I wouldn't eliminate it but i'm not driving his car.
Steve V
Steve V's Automotive 757 560 2782
Jan 5, 2004
4,104
426
83
Elberon,Va
"IF" you have a loose convertor blocking the 1/2 will no be too harsh, a lot depends on personal preference. You can remove the center checkball as well to firm up the shift and leave the accum active, or block the accum and leave the ball , or remove BOTH for max aggression.
Top Bottom
