1987 Turbo -T 27k Miles Mint..
Anarchy
One fast Hot Air
I've read many different posts. Some say high temp rtv. Some say kirban sells a set. Do I need header gaskets or just rtv. Thank u
Used the fel pro kit because I couldn’t make it work cost wise to get the heads and headers decked
I guess I will go against the grain ....most high quality motors should not require gaskets .... I would only use gaskets if necessary ....bc they can blow out .... but if you have to use a gasket ...copper is preferred but as with everything it depends.... and the felpro is another great choice ..and be prepared for crossover alignment issues....
