- Aug 1, 2004
Here is my '87 T.
Cool car.
Cold A/C.
Car went 10.8 somthing at 128mph first and only time to the track. I can't bring myself to put a cage in her, as I'm not a drag racer - just like fast cars!
I'm going to try to add pics as time allows, been prettty busy at work!
Car is in NE Maryland - 21015 zip code.
Asking 17k
List of goodies as follows:
.030 TRW forged pistons $300.00
file fit Plasma Moly rings $115.69
New std/std Buick crank - Bought @ 12 years ago at Englishtown new in box! $600.00
stock rods w/ ARP bolts $73.88
RJC girdle w/crank scraper installed $300.00
RJC crank scraper $55.00
Balanced assembly $250.00
Full Throttle Roller cam - 210/215 .516/.516 110 l/s $663.00
Champion GN1 14 bolt heads w/ "beehive" roller spring upgrade $1,629.00
Scorpion 1.55 roller rockers $260.99
ARP head studs $71.88
F/M “wide" bearings $68.00
New Champion intake with billet fuel rails - not ported stocker! $699.00
70mm Accufab Throttle body $220.00
60 lbs Motrons $318.00
new Walbro 340 $100.00
hotwire kit $35.00
F-BODY RADIATOR $130.00
hood mounted Phantom fuel pressure gauge w/hose and fittings $200.00
Accufab fuel pressure regulator $119.99
Cometic Head gaskets $120.00
Rollmaster timing chain $125.00
high flow water pump $50.00
billet water neck $25.00
High volume ported front cover $130.00
Knock sensor $47.95
Precision 6776 Full Ball bearing turbo w s/cover 4" inlet/3" outlet $1,374.99
Turbo water line kit $75.00
hd actuator $60.00
stainless oil drain tube $49.95
RJC boost controller $45.00
Precision turbo saver remote oil filter set-up $150.00
TA Performance Stainless headers $1,000.00
G-body parts 3" Down Pipe $425.00
2.5" Hooker cat back exhaust $360.00
Precision front mount - About the only part I bought used! $700.00
Alky Control - system by Julio - Dual Nozzle $575.00
Dual Fans – Spal $125.00
Caspers dual fan relay kit $64.95
H/R Parts Driver and Passenger poly engine mounts $209.00
H/R Parts poly Transmission mount $89.95
H/R Parts rear sway bar $489.00
UMI Driveshaft loop $49.95
Pat's 3200 stall lock-up convertor $500.00
3 gauge pillar mount $59.00
Extender extreme g chip $89.00
Innovate Wide band XD-16 $399.99
Translator Gen 2 $250.00
Caspers Gen 2 harness adaptor $99.95
4" inlet pipe $150.00
3.5" maf $70.00
K&N filter $50.00
Scanmaster 2.1 $225.00
trans cooler $50.00
Transmission by Brian Hofer w/trans brake, billet drum ,billet input shaft $2,350.00
Denny's Driveshaft - Nitrous ready model with 1350 U-joints & hd rear yoke $580.00
Moser 30 spline axles w/long studs $257.00
True-Trac posi unit w/install kit $545.00
15X6 FRONT CONVO PROS $460.00
15X8.5 CONVO PROS $500.00
275/60-15 MICKEY THOMPSON DRAG RADIALS $340.00
1987 GN front and rear seats - $700.00
Energy Suspension body bushing kit $129.98
Caspers audible knock detector $64.95
Billet vacuum block $39.95
Caspers fan hi/lo switch $39.95
G-body parts silicone vacuum line kit $55.00
Intercooler/turbo hoses @ 100.00 $100.00
Angled bilet IAC boss $59.99
copper turbo gasket $20.00
Phantom temp gauge $59.95
Phantom boost gauge $46.95
Phantom oil gauge $39.95
MSD wires $60.88
Copper header gasket $29.95
Phantom trans temp gauge $46.88
Maf adaptor $10.00
New GM Headlight Bezels $200.00
New GM grill $400.00
New paint $3,000.00
TOTALS Total $24,629.49 (plus a car to install this stuff on!)
Cool car.
Cold A/C.
Asking 17k
hotwire kit $35.00
Knock sensor $47.95
hd actuator $60.00
3.5" maf $70.00
K&N filter $50.00
trans cooler $50.00
MSD wires $60.88
Maf adaptor $10.00
New paint $3,000.00
